Bashan BS7 onderdelen overzicht deel 1
Berichtdoor DenniZ » 20 apr 2010 19:45
1 MOTOR ASSY
2 INLET TUBE
3 ENGINE OUTER COVER
4 CARBURETOR
5 WATER TANK
6 AIR FILTER
7 MUFFLER
8 HEXANGULAR AXLE 10*115
9 VICE WATER TANK
10 BATTERY
11 ELECTROLYTE
12 REGULATOR
13 IGNITION
14 IGNITION COIL
15 MAIN CABLE COMP
16 STARTING RELAY
17 CHAIN
18 SHIFTTING PEDAL
19 FRONT SUSPENSION OF MOTOR
20 HIGH TEMPERATURE
21 HIGH TEMPERATURE
22 WATER TUBE ASSY
23 WATER TUBE ASSY
24 BAND
25 WATER TUBE
26 BOLT M8
Keer terug naar Onderdelenoverzichten
